Run Subsonic and Madsonic on the same PC/Server?
Posted: 30 Oct 2013, 22:18
by apastuszak
Is it possible to run Subsonic and Madsonic at the same time, but on different ports?
Re: Run Subsonic and Madsonic on the same PC/Server?
Posted: 31 Oct 2013, 07:48
by hanshans
yes, but why ? :-)
Posted: 01 Nov 2013, 03:41
by apastuszak
So, I can test my Subsonic clients and see if they work with the Madsonic back end.
Posted: 03 Nov 2013, 19:42
by skopo
I'm using Virtualbox and other lan-card for that.
Posted: 14 Nov 2013, 17:13
by maxslug
Yes.
I run both to try out new builds of each. on unix I install one in /var/madsonic and one in /var/subsonic
You just need two copies of the shell script, which you already have -- /usr/bin/subsonic and /usr/bin/madsonic
make sure that in there they point to the right directories, and assign them to different ports et voila.
-m
