Settings/Users error
Beowolf
Unread post by Beowolf »
I have the following error in settings under users page no other
Error
Subsonic encountered an internal error. You can report this error in the Subsonic Forum. Please include the information below.
Exception org.apache.jasper.JasperException
Message /WEB-INF/jsp/userSettings.jsp(171,8) "${command.newUser or }" contains invalid expression(s): javax.servlet.jsp.el.ELException: Encountered "}", expected one of [, , , "true", "false", "null", "(", "-", "not", "!", "empty", ]
Java version Oracle Corporation 1.7.0_13
Operating system Windows 7 6.1
Server jetty-6.1.x
Memory Used 79 of 150 MB
Stack trace org.apache.jasper.JasperException: /WEB-INF/jsp/userSettings.jsp(171,8) "${command.newUser or }" contains invalid expression(s): javax.servlet.jsp.el.ELException: Encountered "}", expected one of [, , , "true", "false", "null", "(", "-", "not", "!", "empty", ]
at org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:39)
at org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:405)
at org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:196)
at org.apache.jasper.compiler.JspUtil.validateExpressions(JspUtil.java:596)
at org.apache.jasper.compiler.Validator$ValidateVisitor.getJspAttribute(Validator.java:1112)
at org.apache.jasper.compiler.Validator$ValidateVisitor.checkXmlAttributes(Validator.java:937)
at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:710)
at org.apache.jasper.compiler.Node$CustomTag.accept(Node.java:1441)
at org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2163)
at org.apache.jasper.compiler.Node$Visitor.visitBody(Node.java:2213)
at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:730)
at org.apache.jasper.compiler.Node$Visitor.visit(Node.java:2219)
at org.apache.jasper.compiler.Node$Root.accept(Node.java:456)
at org.apache.jasper.compiler.Validator.validate(Validator.java:1489)
at org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:166)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:295)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:276)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:264)
at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:563)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:303)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:362)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:712)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:268)
at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:126)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:139)
at org.mortbay.jetty.Server.handle(Server.java:313)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:506)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:830)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:381)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:396)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:442)
Beowolf
Re: Settings/Users error
Updated to latest Beta and fixed
These users thanked the author Beowolf for the post:
