The Upload Function..
uploadsucks
Unread post by uploadsucks »
Is there a way to edit the destination of the upload?
GJ51
Has thanked: 42 times
Been thanked: 83 times
Re: The Upload Function..
Unread post by GJ51 »
In Subsonic it used to be an editable setting on the "More" page. Now, in Madsonic the upload parameters are visible in a pop-up window accessed by clicking on the upload icon. When the window opens there is an entry box for the "Uploas to" directory, but I'm unable to edit it. I tried selecting a file to upload to see if that would enable editing of the upload directory, but it appears that editing the directory just isn't active.
I also looked in the file in the C:\Subsonic directory that holds most of the settings parameters but couldn't find it in there either, so it looks like this is a bug that need to be fixed.
uploadsucks
Good man GJ51. We need to petition the coding overlords to get this function fixed. It's integral to the whole system.
GJ51
The overlords have been made aware!
I never noticed it before as I have all my uploads done through Filezilla.
We're still in beta, so I'm sure it will get fixed.
