Incorrect album count stats
Posted: 14 Jan 2013, 18:01
I upgraded from 4.7 to the latest 4.8.3312.beta3 over the weekend and the album count statistic is now way off. Previously it was a little over 4000 albums (forget the exact number), which roughly matches what Winamp reports for the same folders. Now 4.8 is reporting 3600 albums. I've done several full rescans (disable, scan, cleanup, enable, scan) and it keeps coming up with the 3600 album count. The total file/track count (47,000+ ) is very close in both Madsonic and Winamp, so I don't think the scan is missing any files.
I ran a "SELECT * FROM media_file where TYPE='ALBUM'" query and got 4000+ rows, so that seemed OK. However, "SELECT * FROM album" only returns 3600 rows. So there seems to be some inconsistency between the two.
Additional info:
- 3 media folders
- all follow Root\AlbumArtist\Album structure
- all files are FLAC with Vorbis comment tags
- album tag is populated in all files
Obviously, the count being incorrect isn't a big deal (though it would be nice). However, I'm worried that album table might be missing records which could affect searching and/or browsing, right?
Let me know if there's anything else I can do to help.
Additional info:
- 3 media folders
