ffmpeg transcoder issue on bananapi(lubuntu)
shah_rear
Unread post by shah_rear »
HI
Greetings !!!
I have bananapi with lubuntu installed and Madsonic versions is 5.1.5200. Java (javac 1.7.0_75) and other prerequisite is also installed. ffmpeg, lame,xmp can be found /var/madsonic/transcode location. Also no other ffmpeg,lame,flac,xmp is installed is the system.
Problem is - Video can not be found or load via web player(html5) when trying to play a video file. But if i change the default setting from transcode menu into /usr/bin/ffmpeg, video file will play but taking long time to load. It took almost 5-10 minutes and sometimes it just keep loading and loading....
Somobody please explain why transocode default setting changing into /usr/bin/ffmpeg works and what is the resolutions to overcome the loading process time ??
Thanks is advance - shahrear
