I'm running Madsonic on a linux distribution (Raspbian). I was wondering if there's a way to get madsonic to add the hidden folder to my library (folder name starting with '.').
My folder structure is /Music/<Artist>/<Albums>
For example I have 2 Rancid albums "...And Out Come The Wolves" and "...Honor Is All We Know". For now I get away by removing the "..." but then the "Artist TopAlbum" tag does not work since the name is not exactly the same.
Cheers
[solved] Madsonic hidden folder
Re: Madosnic hidden folder
I managed to get the proper behavior by disabling the option "Enable AlbumSet/Folder Parsing". It seems to be reading the ID3 tag instead of the folder structure.
Cheers!
Cheers!
