WEBPLAYER doesn't START, but CAN DOWNLOAD
etyrnal
Has thanked: 31 times
Been thanked: 11 times
Unread post by etyrnal »
What does it mean if the web player looks like it starts to load the song, but the buffer never starts filling or playing...
YET... i can click the download song link... and it starts downloading? hmmmm???
:shock: :?: :shock:
chali
Has thanked: 18 times
Been thanked: 35 times
Re: WEBPLAYER doesn't START, but CAN DOWNLOAD
Unread post by chali »
etyrnal wrote:What does it mean if the web player looks like it starts to load the song, but the buffer never starts filling or playing...
:shock: :?: :shock:
When I get this, it is because the hard drive slowed down, (to save energy)
it usually takes 10-25 sec before the hdd booted up after pressing play,
easiest way to get around this is either to start another film
(usually does not work to try to start the same movie without starting another first)
otherwise it tend to work well clicking on "open in new window"
/ Regards
GJ51
Has thanked: 42 times
Been thanked: 83 times
Unread post by GJ51 »
You should check the logs. It should have an error in it listed. I suspect you're getting a transcoding error which simply kills the stream to the player. The download should still work as it's probably just downloading the track in it's original format.
