Exception org.springframework.jdbc.CannotGetJdbcConnectionException
Message Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: /var/madsonic/db/subsonic.log
Java version Oracle Corporation 1.7.0_51
Operating system Linux 3.11.0-15-generic
Server jetty/8.y.z-SNAPSHOT
Memory Used 138 of 290 MB
Stack trace org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: /var/madsonic/db/subsonic.log
at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:82)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:577)
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
at net.sourceforge.subsonic.dao.UserDao.getUserByName(UserDao.java:76)
at net.sourceforge.subsonic.service.SecurityService.getUserByName(SecurityService.java:131)
at net.sourceforge.subsonic.controller.MultiController.login(MultiController.java:104)
at sun.reflect.GeneratedMethodAccessor7.invoke(Unknown Source)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:135)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:667)
at java.lang.Thread.run(Thread.java:744)
Caused by: java.sql.SQLException: File input/output error: /var/madsonic/db/subsonic.log
at org.hsqldb.jdbc.Util.sqlException(Unknown Source)
at org.hsqldb.jdbc.jdbcConnection.(Unknown Source)
at org.hsqldb.jdbcDriver.getConnection(Unknown Source)
at org.hsqldb.jdbcDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(DriverManager.java:571)
at java.sql.DriverManager.getConnection(DriverManager.java:187)
at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:174)
at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriver(DriverManagerDataSource.java:165)
at org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnectionFromDriver(AbstractDriverBasedDataSource.java:149)
at org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnection(AbstractDriverBasedDataSource.java:119)
at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:113)
at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:79)
... 76 more
