I install madsonic (latest version as of this post) using the standalone.
I create a:
I upload and extract this (I have tried the Debian 7 included version but it is not related to the issue I have):
FFmpeg Static Builds by Burek
ffmpeg.static.64bit.2013-06-14.tar.gz
Flac to Mp3
This transcoder command does not work:
Audioffmpeg -i %s -ab 256k -ar 44100 -ac 2 -v 0 -f mp3 -
It must be changed to this:
what does the
Audioffmpeg do? IT works ok if i just use
ffmpeg. But the installer comes with this by default so this requires a manual edit.
