I get the following error whenever I try to select a specific album (RAM by Daft Punk). Just started happening today. It seemed to initially happen when I clicked on "set recommended" for the album. I have tried removing the album folder, then rescanning and then using the "cleanup database" tool, but it comes right back. I'd rather not have to reset the database, but if I do, that's the price of running a beta I guess. :S
Windows 7 64-bit
AMD Phenom 2 (6-core)
Error
Exception org.springframework.dao.IncorrectResultSizeDataAccessException
Message Incorrect result size: expected 1, actual 2
Java version Oracle Corporation 1.7.0_21
Operating system Windows 7 6.1
Server jetty-6.1.x
Memory Used 98 of 145 MB
Stack trace org.springframework.dao.IncorrectResultSizeDataAccessException: Incorrect result size: expected 1, actual 2
at org.springframework.dao.support.DataAccessUtils.requiredSingleResult(DataAccessUtils.java:74)
at org.springframework.jdbc.core.JdbcTemplate.queryForObject(JdbcTemplate.java:722)
at org.springframework.jdbc.core.JdbcTemplate.queryForObject(JdbcTemplate.java:732)
at org.springframework.jdbc.core.JdbcTemplate.queryForInt(JdbcTemplate.java:759)
at net.sourceforge.subsonic.dao.HotDao.getHotFlag(HotDao.java:48)
at net.sourceforge.subsonic.service.HotService.getAlbumHotFlag(HotService.java:81)
at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:152)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:712)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:139)
at org.mortbay.jetty.Server.handle(Server.java:313)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:506)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:830)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:381)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:396)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:442)
Re: IncorrectResultSizeDataAccessException
Another thought... I was recently changing the mp3tag version of my audio files to be compatible with the moods feature, which means I updated them to ID3v2.4. However, mediamonkey only writes to ID3v2.3, and every time I use mediamonkey to update the tags, it overwrites the ID3v2.4 tags with ID3v2.3. Might be related...
Edit: and my version is 5.0.3480.beta2.
