Howto get correct Artist Hub content?
hpoltzka
Unread post by hpoltzka »
Using Madsonic 3320-beta3
I have a folder Structure like:
%artist% - %album% (%year%)\%discnumber%.%tracktitle% - %title%
Now in the Artist Hub I only get the folder names instead of proper artists.
Isn't it possible to get the Artists from the Id3/vorbis tags, instead of relying on folder structure?
Is there an way to fix that, without changing my folder structure?
jonnymnemo
Has thanked: 3 times
Been thanked: 6 times
Re: Howto get correct Artist Hub content?
Unread post by jonnymnemo »
It would be really better to add an "artist" folder at the beginning of your structure !
Madsonic would be faster, and you would not have this problem ! ;)
I understand your question, but I don't have an answer (what a troller I am !!).
However, this would need to have perfect tags for all your albums !
hpoltzka
jonnymnemo wrote:However, this would need to have perfect tags for all your albums !
I have perfect tags, however Folder names are sometimes not perfect - depending on filesystem you have certain restraints (special characters, folder length)...
Let's see what the developers say about this issue :?:
