Hello
I have a problem with integration active directory.
After set LDAP url and etc, create user with "Authenticate user in LDAP"... but that user after type username and password error below show:
HTTP ERROR 500 org.springframework.ldap.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-03100288, problem 2001 (NO_OBJECT), data 0, best match of: 'DC=X,DC=com' ?]; nested exception is javax.naming.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-03100288, problem 2001 (NO_OBJECT), data 0, best match of: 'DC=X,DC=com' ?]; remaining name 'OU=X,OU=X,DC=X,DC=com'
URI: /j_spring_security_check
STATUS: 500
MESSAGE: org.springframework.ldap.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-03100288, problem 2001 (NO_OBJECT), data 0, best match of: 'DC=X,DC=com' ?]; nested exception is javax.naming.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-03100288, problem 2001 (NO_OBJECT), data 0, best match of: 'DC=X,DC=com' ?]; remaining name 'OU=X,OU=X,DC=X,DC=com'
SERVLET: default
CAUSED BY: org.springframework.ldap.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-03100288, problem 2001 (NO_OBJECT), data 0, best match of: 'DC=X,DC=com' ?]; nested exception is javax.naming.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-03100288, problem 2001 (NO_OBJECT), data 0, best match of: 'DC=X,DC=com' ?]; remaining name 'OU=X,OU=X,DC=X,DC=com'
CAUSED BY: javax.naming.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-03100288, problem 2001 (NO_OBJECT), data 0, best match of: 'DC=X,DC=com' ?]; remaining name 'OU=X,OU=X,DC=X,DC=com'
Caused by:
'DC=X,DC=com'
'DC=X,DC=com'
at org.springframework.ldap.support.LdapUtils.convertLdapException(LdapUtils.java:183)
at org.springframework.ldap.core.LdapTemplate.search(LdapTemplate.java:376)
at org.springframework.ldap.core.LdapTemplate.search(LdapTemplate.java:328)
at org.springframework.ldap.core.LdapTemplate.search(LdapTemplate.java:629)
at org.springframework.ldap.core.LdapTemplate.search(LdapTemplate.java:570)
at org.springframework.security.ldap.SpringSecurityLdapTemplate.searchForSingleAttributeValues(SpringSecurityLdapTemplate.java:171)
at org.madsonic.ldap.MadsonicLdapAuthoritiesPopulator.getGroupMembershipRoles(MadsonicLdapAuthoritiesPopulator.java:178)
at org.madsonic.ldap.MadsonicLdapAuthoritiesPopulator.getGrantedAuthorities(MadsonicLdapAuthoritiesPopulator.java:150)
at org.madsonic.ldap.UserDetailsServiceBasedAuthoritiesPopulator.getGrantedAuthorities(UserDetailsServiceBasedAuthoritiesPopulator.java:119)
at org.springframework.security.ldap.authentication.LdapAuthenticationProvider.loadUserAuthorities(LdapAuthenticationProvider.java:197)
at org.springframework.security.ldap.authentication.AbstractLdapAuthenticationProvider.authenticate(AbstractLdapAuthenticationProvider.java:82)
at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:156)
at org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter.attemptAuthentication(UsernamePasswordAuthenticationFilter.java:92)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:211)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:193)
at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1601)
at org.madsonic.filter.MetricsFilter.doFilter(MetricsFilter.java:54)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:201)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.gzip.GzipHandler.handle(GzipHandler.java:763)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:400)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:645)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:392)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555)
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410)
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
Caused by: javax.naming.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-03100288, problem 2001 (NO_OBJECT), data 0, best match of:
'DC=X,DC=com'
at com.sun.jndi.ldap.LdapCtx.mapErrorCode(Unknown Source)
at com.sun.jndi.ldap.LdapCtx.processReturnCode(Unknown Source)
at com.sun.jndi.ldap.LdapCtx.searchAux(Unknown Source)
at com.sun.jndi.ldap.LdapCtx.c_search(Unknown Source)
at com.sun.jndi.toolkit.ctx.ComponentDirContext.p_search(Unknown Source)
at com.sun.jndi.toolkit.ctx.PartialCompositeDirContext.search(Unknown Source)
at javax.naming.directory.InitialDirContext.search(Unknown Source)
at org.springframework.ldap.core.LdapTemplate$4.executeSearch(LdapTemplate.java:322)
at org.springframework.ldap.core.LdapTemplate.search(LdapTemplate.java:363)
... 74 more
Powered by Jetty:// 9.4.44.v20210927
Please help to solve that.
LDAP Integration Problem
- Been thanked: 0
Jump to
- ↳ Info / Announcements
- ↳ Voting Polls
- ↳ Madsonic Client
- ↳ Support
- ↳ Feature Requests
- ↳ Madsonic Node
- ↳ Support
- ↳ Madsonic Server
- ↳ Info
- ↳ Support
- ↳ Plugins & Addons
- ↳ Docker
- ↳ UnRAID
- ↳ FreeBSD
- ↳ FreeNAS
- ↳ Synology
- ↳ QNAP
- ↳ OpenMediaVault
- ↳ Netgear
- ↳ Asustor
- ↳ MusicBee
- ↳ Tomahawk
- ↳ XBMC
- ↳ Clementine
- ↳ KODI
- General
- ↳ Info
- ↳ Announcements
- ↳ Voting Polls
- ↳ General
- ↳ Development
- ↳ Development Voting Polls
- ↳ Client 6.x
- ↳ Info
- ↳ Support
- ↳ Bug Reports
- ↳ Solved Requests
- ↳ Server 5.x
- ↳ Support 5.x
- ↳ Bug Reports 5.x
- ↳ Feature Requests 5.x
- ↳ Server 6.x
- ↳ Info
- ↳ Support 6.x
- ↳ Bug Reports 6.x
- ↳ Feature Requests 6.x
- ↳ Solved Requests
- ↳ Node 6.x
- ↳ Info
- ↳ Support
- ↳ Download
- ↳ Madsonic 6.x
- ↳ Madsonic Transcoding
- ↳ Player / Tools / Themes
- ↳ Scripts
- ↳ Off Topic
