Users permissions issue
Posted: 12 Apr 2022, 12:46
I installed a madsonic server a few days ago.I'm pretty much ok with everything but I'm meeting an issue with users permissions.
I installed on a Debian 10 VM. Everything runs smoothly in my private LAN as much on the Internet.
Here's the issue :
I mounted two libraries LA and LB as samba shares in different folders on my server.
I created two users, A and B.
I created two groups Group A and Group B, so A is in Group A and B is in Group B.
Group B can only see library LB.
Group A can only see library LA.
As you can imagine, my issue is that in any remote android client I used, as within the web interface, each user can see all elements (tags, artists, albums etc ...) from the user, despite the permissions I set up.
I would like to keep things separated, am I missing something ?
I activated the logs in the interface and tested accessing an album I shouldn't be able to see with my client (substreamer) but I am not seeing much.
Here's the issue :
