server 5.1 anyone?
Posted: 16 Oct 2019, 22:22
by whatsisname
hi all, anyone have a copy of 5.1 version of server? can't find a copy anywhere.
w.
Re: server 5.1 anyone?
Posted: 28 Apr 2020, 01:53
by JwlzT
I realize this is an old post but I'll put this information here in case anyone else wanders in and needs it.
The .deb download may not available anymore but if you still have the .war file from an old install, you can try installing a slightly newer version and replace its .war file with the one from 5.1.
Posted: 28 Apr 2020, 17:46
by whatsisname
hi thanks for this suggestion. I tried doing as you described but after doing so I could no longer login. I tried loads of work arounds, resets, but no joy.
I think this may be the only software I've ever used that I couldn't download an older version of. pretty irritating.
Posted: 22 May 2020, 21:40
by JwlzT
[Context: I'm using the Debian/Ubuntu version, so your mileage may vary if you run a different server.]
Which newer version did you try?
Version 6 should work the way I described. You install version 6, then replace the war file with the one from your version 5 install.
