info
Posted: 14 Dec 2018, 16:22
I use server version MADSONIC 6.3.9840.3e2ad42.20180107.0908
I wanted to know there is the possibility of having a single streaming stream, without identifying multiple players (eg vlc or mpv) for a single account.
I tried to populate the terminals with the software for the nodes, but in the customization of the player does not give me the opportunity to select that type of playback (node), as if I were not authorized
and then I wanted to know if there is the possibility once a playlist is created, which is the procedure to add some songs.
the only way I found it at the moment is to play the playlist on playqueue that I am interested in repopulating and adding the songs from the index artists
I would like to update the playlist without having to do it again.
thank you
thank you
