Version: MADSONIC 6.2.9040.9b189e7.20161208.0650
Server: jetty/8.y.z-SNAPSHOT, java 1.8.0_151, Linux 4.9.61-odroidxu4 (arm)
Hi, I'm having trouble accessing my Madsonic server via the app to android that says this under "test connection":
"Connection failure. Incompatible versions. Pleas upgrade Masonic server.
I have no trouble accessing the interface via web browser both locally and from outside when I opened the port in the router. I only have problems via the android app. What can the problem be? If you need log files can i send them ?
Thanks in advance
Rene
Can not connect to android ?
- Been thanked: 0
