getAlbumList exposes all albums despite user access
Posted: 07 Nov 2017, 00:44
with rest API:
thus a less privileged user can see all the available songs on the server despite only having access to a certain folder.
this can be addressed for client app use by using the getMusicFolders method then calling the getAlbumList with only those folder id's. This, however, shouldn't be necessary. getAlbumList should only return album ids that the user has access to.
Thanks.
MADSONIC 6.2.9080.2a5cd1f.20161222.0530
MADSONIC REST API v2.5.0, SUBSONIC REST API v1.14.0
jetty/8.y.z-SNAPSHOT, java 1.8.0_152, Linux 4.13.9-1-ARCH (amd64) (419.5 MB / 1.41 GB)
Thanks.
