Could someone let me know how to resolve this?
Exception java.io.FileNotFoundException
Message c:\Media\Playlists\Backup\The White Stripes.m3u8 (The system cannot find the path specified)
Java version Oracle Corporation 1.8.0_31
Operating system Windows Server 2012 R2 6.3
Server jetty/8.y.z-SNAPSHOT
Memory Used 112 of 458 MB
Stack trace java.io.FileNotFoundException: c:\Media\Playlists\Backup\The White Stripes.m3u8 (The system cannot find the path specified)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.(Unknown Source)
at java.io.FileWriter.(Unknown Source)
at org.madsonic.service.PlaylistService.backupAllPlaylists(PlaylistService.java:303)
at org.madsonic.controller.CleanupSettingsController.handleRequestInternal(CleanupSettingsController.java:148)
Backing up Playlists Error
- Has thanked: 3 times
- Been thanked: 2 times
Re: Backing up Playlists Error
Having the same issue, different playlist. I don't know why it's being called but that definitely isn't where it would be.
Well, got rid of the problem by going to settings>playlist>delete all playlists but not sure if that's a good enough answer for you
