Cant get service to go green
I had Madsonic up and running v6 and did an upgrade but now I can't get the service status to go green. I have restarted the computer and also checked to see that the service is running but all that the tray icon will do is change from Not running. Auto-start. to Running. Auto-start. the rest will not populate and turn green. Does anyone know what to do? I can run Subsonic fine. But when I stop it and try to run Madsonic it won't work like it used to.
