Password Reset but new Password Doesn't Work
KicknGuitar
Has thanked: 6 times
Been thanked: 5 times
Unread post by KicknGuitar »
I found myself confused after trying to log in, resetting my password, then trying to log in, reset, etc. with no luck. (Correct login name, all lower caps...)
I even checked the madsonic.script file using Mind24's Blogpost about finding Subsonic user passwords.
Still not letting me log in.
I don't see anything to help me in the log file:
[2016-06-27 17:41:07,690] WARN HsqlDaoHelper - Checking database schema ...
[2016-06-27 17:41:11,656] INFO HsqlDaoHelper - Done checking database schema.
[2016-06-27 17:41:11,658] INFO HsqlDaoHelper - Checking HSQLDB version: 2.3.3
[2016-06-27 17:41:13,765] INFO SettingsService - Java: 1.7.0_71, OS: Mac OS X
[2016-06-27 17:41:13,787] INFO SettingsService - write transcode path to property file.
[2016-06-27 17:41:14,347] INFO SettingsService - ffmpeg: WARNING no transcoder found!
[2016-06-27 17:41:15,897] INFO MediaScannerService - Automatic index scan: every 1 day(s)
[2016-06-27 17:41:15,897] INFO MediaScannerService - NEXT: Tue Jun 28 04:00:00 EDT 2016
[2016-06-27 17:41:16,446] INFO UPnPService - Checking UPnP service...
[2016-06-27 17:41:16,883] INFO PodcastService - Automatic Podcast scan: every 24 hour(s)
[2016-06-27 17:41:16,884] INFO PodcastService - NEXT: Mon Jun 27 17:46:16 EDT 2016
[2016-06-27 17:41:17,124] INFO UPnPService - Disabling UPnP/DLNA media server
[2016-06-27 17:41:17,125] INFO UPnPService - Checking UPnP service - Done!
[2016-06-27 17:42:06,182] INFO BootstrapVerificationFilter - Servlet container: jetty/8.y.z-SNAPSHOT
[2016-06-27 17:42:27,682] WARN LoginFailureLogger - Login failed for [kicknguitar] from [192.168.1.2]
[2016-06-27 17:43:15,013] WARN LoginFailureLogger - Login failed for [admin] from [192.168.1.2]
[2016-06-27 17:43:34,711] INFO NetworkService - Successfully forwarding port 4040.
[2016-06-27 17:46:16,876] INFO PodcastService - Starting scheduled Podcast refresh.
[2016-06-27 17:46:16,878] INFO PodcastService - Completed scheduled Podcast refresh.
[2016-06-27 17:47:20,823] WARN LoginFailureLogger - Login failed for [kicknguitar] from [192.168.1.2]
I'd offer more but I'm not sure where to grab info on the server (I think it's the latest 6.x version from May) and what else to provide for help.
Also, how can I reset the password to ensure it'll work since the passwords from the madsonic.server file doesn't work?
VikingOy
Has thanked: 3 times
Re: Password Reset but new Password Doesn't Work
Unread post by VikingOy »
To get assistance, you must as minimum supply info about:
What HW are running it on
What OS and version
What version of Madsonic
jsgates
Been thanked: 15 times
Unread post by jsgates »
I can confirm this issue as well. I have seen it happen a few times with my users. It seem to be intermittent.
issue confirmed and fixed with next Madsonic build.
