VERSION: MADSONIC 6.0 | BUILD: 7860
SERVLET: TOMCAT (PROXY REVERSE WITH NGINX)
SERVER: CPU: AMD 64 | ARCH: X64 | MEMORY: 16GB | HDD: 1TB
OS: UBUNTU SERVER 15.10
SYSTEM: SERVER
INSTALLER: WAR
JAVA: ORACLE JDK 1.8 ( java 1.8.0_66)
BROWSER: FIREFOX 43
CLIENT: Mobile application Android 5.7
DESCRIPTION: Can't connect
REPRODUCIBLE: YES
Thanks again for your great work.
I have an important issue with the mobile application (only since 5.6/5.7) on Android, i get the error "Connection failure. Wrong username or password.". But I'm sure of my credentials and i connect successfully to the web interface.
I checked the log on my server and i get the error :
80.12.x.x - - [13/Jan/2016:15:52:05 +0100] "POST /rest2/ping.view?u=myuser&t=44207f328572cbc018b086db92axxxx&s=[B@8403xx&v=2.0.0&c=madsonic HTTP/1.1" 200 224 "-" "-"
<madsonic-response status="failed" version="2.2.0" type="madsonic"><error code="40" message="Wrong username or password."/></madsonic-response>
<madsonic-response status="ok" version="2.2.0" type="madsonic"/>
Thanks in advance
wared
