I have a bunch of playlists on my 5.x server, and I thought since the actual files (backups) are in a folder accessible to my 6.x server, that I could just import them, and all would be good.
But when I import a playlist manually, or if I import from a backup, nothing happens. No playlists are imported, even after a normal rescan.
The only thing I can think of is that the paths to the files are different (since my 5.x server is on Linux and the 6.x server is on Windows).
Could there be another reason?
