Java - Update-Alternatives
Good afternoon. After installing Madsonic and using instructions on the web for the Raspberry Pi. Everything worked great, except when I lost power and the Pi rebooted. It wasn't until i retyped the command "sudo update-alternatives —set java /opt/jdk1.8.0/bin/java" did Madsonic come up again. Is there a way to make this persistent so I don't have to type this every time the Pi reboots? Thanks...
