Updated without problems but my main problem is not fixed in 7600
First track starts and shortly after the sql action is taking over. Transcoding for the second track never starts...
[2015-10-09 16:59:03,141] WARN HsqlDaoHelper - Checking database schema ...
[2015-10-09 16:59:03,683] INFO HsqlDaoHelper - Done checking database schema.
[2015-10-09 16:59:03,685] INFO HsqlDaoHelper - Checking HSQLDB version: 2.3.3
[2015-10-09 16:59:03,805] INFO SettingsService - Java: 1.7.0_05, OS: Linux
[2015-10-09 16:59:04,029] INFO MediaScannerService - Automatic index scan: every 1 day(s)
[2015-10-09 16:59:04,029] INFO MediaScannerService - NEXT: Sat Oct 10 03:00:00 CEST 2015
[2015-10-09 16:59:04,068] INFO UPnPService - Checking UPnP service...
[2015-10-09 16:59:04,104] INFO PodcastService - Automatic Podcast scan: every 24 hour(s)
[2015-10-09 16:59:04,104] INFO PodcastService - NEXT: Fri Oct 09 17:04:04 CEST 2015
[2015-10-09 16:59:04,156] INFO UPnPService - Disabling UPnP/DLNA media server
[2015-10-09 16:59:04,156] INFO UPnPService - Checking UPnP service - Done!
[2015-10-09 16:59:08,616] INFO BootstrapVerificationFilter - Servlet container: jetty/8.y.z-SNAPSHOT
[2015-10-09 16:59:14,075] WARN NetworkService - No UPnP router found.
[2015-10-09 17:00:23,396] INFO SettingsService - write to transcode path to property file.
[2015-10-09 17:00:23,627] INFO PlayQueueInputStream - admin listening to "Federn/03 - Hubert von Goisern - Es is wahr.
flac"
[2015-10-09 17:00:23,650] INFO TranscodeInputStream - Starting transcoder: [/var/madsonic/transcode/ffmpeg] [-i] [/mp3
/Hubert von Goisern/Federn/03 - Hubert von Goisern - Es is wahr.flac] [-map] [0:0] [-b:a] [192k] [-v] [0] [-f] [mp3] [
[2015-10-09 17:00:24,533] DEBUG AudioScrobblerService - Successfully registered now playing for song 'Es is wahr' for
user xxx at Last.fm: Fri Oct 09 17:00:23 CEST 2015
[2015-10-09 17:00:30,562] DEBUG AudioScrobblerService - Successfully registered submission for song 'Es is wahr' for u
ser xxx at Last.fm: Fri Oct 09 17:00:29 CEST 2015
[2015-10-09 17:00:45,252] DEBUG AbstractDao - 3975 ms: select id, path, folder, type, override, format, data, title,
album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variab
le_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment
, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where t
ype=? and lower(title)=? and present
[2015-10-09 17:00:48,578] DEBUG AbstractDao - 4281 ms: select id, path, folder, type, override, format, data, title,
, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where type=? and lower(title)=? and present
[2015-10-09 17:00:49,350] DEBUG AbstractDao - 4097 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where type=? and lower(title)=? and present
[2015-10-09 17:00:54,297] INFO PlayQueueInputStream - admin listening to "Federn/04 - Hubert von Goisern - So a Segen.flac"
[2015-10-09 17:00:55,967] DEBUG AbstractDao - 7388 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where type=? and lower(title)=? and present
[2015-10-09 17:00:58,041] DEBUG AbstractDao - 8690 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where type=? and lower(title)=? and present
[2015-10-09 17:08:06,135] DEBUG AbstractDao - 8844 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where type=? and lower(title)=? and present
[2015-10-09 17:08:06,135] DEBUG AbstractDao - 10917 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where type=? and lower(title)=? and present
