I like it, BUT can you add something else such as madsonic="2.0.0" so I know that I can also use 2.0.0. Otherwise I will run the first test and it will return 1.13.0 and I will just continue on ignoring the newer API version.
With that I have no way of knowing that I can switch to using the 2.0 API for Madsonic. By default I will send a request saying that the app requires a min of 1.2. It will then respond with saying that it is subsonic and the version is 1.13. I will have no way of knowing that it is a Madsonic server and I can switch to 2.0. In the first response some sort of madsonic-version would be nice so I can key onto that and use it.
daneren2005 wrote:With that I have no way of knowing that I can switch to using the 2.0 API for Madsonic. By default I will send a request saying that the app requires a min of 1.2. It will then respond with saying that it is subsonic and the version is 1.13. I will have no way of knowing that it is a Madsonic server and I can switch to 2.0. In the first response some sort of madsonic-version would be nice so I can key onto that and use it.
Hi Scott,
i saw the same problems with the madsonic client, so i changed some things that help API clients to communicate with the server.
