I used the Clean-up database feature to get rid of a few changed directories. I check the app to make sure the directories were cleaned; they were. So I proceeded to play some music and my go to choice is starred songs. I get an error "github.madmarty.madsonic.service.parser.SubsonicRESTException:NullPointerException" and it happens anytime I try to browse starred songs on my Android phone using the madsonic app.
This had me concerned that all my starred music was gone so I checked it via the browser login and every song is there. I know they are there but why dont they work on the app anymore. I attached my logfile as well. This shows the request and error.
Hope this is enough information and I can post more if necessary.
Java Error in Droid App
- Attachments
- madsonic.log
- Shows error coming from the Server
- (29.96 KiB) Downloaded 136 times
Re: Java Error in Droid App
mhh try to check your starred files via webbrowser -> DB .. if there are more than 1 entry per artist/album/value, then remove them.
or remove them completly and start over again ... just to test and reproduce this behavior.
