Some hints on the new 5.2.5300
DoCC
Has thanked: 40 times
Been thanked: 65 times
Post by DoCC »
Build: Latest beta release – Madsonic 5.2.5300
OS : ubuntu 14.04 LTS x64
Host: vmware
CPU: 4 x 1 Kernel á 3,4 GHz
RAM OS: 2048 MB
RAM madsonic: 512 - 1500 MB
Settings > Last.FM
"Enalbe LastFM TopTrack search"
verschrieben : )
- Pandora working , works perfect !!! My setting 2,0,3,10,0,4
- Mediascanning working
MadEvil : Please consider an own little db file for the podcasts.
After beginning from scratch i had to copy my settings manually within the madsonic.script files.
Thanks in advance
DoCC
Re: Some hints on the new 5.2.5300
Post by DoCC »
I guess the "rights management console" is a bit buggy ??
If you have several folders ... 28 +
i.e. podcast, # and alpabetical order ( a,b,c,...,z)
and you add another one, there are no settings available
Anyone seen this before ?
DoCC
Post by DoCC »
God damn it ...
Sometimes i really don't know what the heck is going on.
I have added some content. Then i hit the "Scan musicfolders now" button.
First i got some error messages like " error java heap space " .
These were ocurring somtimes after 4500 tracks scanned, sometimes after 10k but mostly direct at start about 500 tracks scanned.
... Ok doing some reseach i increased the java initial memory form 256 > 512 and the max mem from 512 > 2048
Scanning again, fail messages telling me the connection to the hsqldb is lost ?? can't be.
i stopped the deamon, renamed the db, started it again, it won't fire up. WTF ?? no db from scratch ?? grr ^^
ok renaming it back, restarting the deamon, madsonic comes up.
i decieded to clean the db ... ERRORRRRRR
Exception	org.springframework.dao.TransientDataAccessResourceException
Message	PreparedStatementCallback; SQL [select top 1 id from media_file where not present]; org.hsqldb.HsqlException: java.io.IOException: java.lang.IndexOutOfBoundsException; nested exception is java.sql.SQLException: org.hsqldb.HsqlException: java.io.IOException: java.lang.IndexOutOfBoundsException
Java version	Oracle Corporation 1.7.0_65
Operating system	Linux 3.13.0-32-generic
Server	jetty/8.y.z-SNAPSHOT
Memory	Used 252 of 620 MB
Stack trace	org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select top 1 id from media_file where not present]; org.hsqldb.HsqlException: java.io.IOException: java.lang.IndexOutOfBoundsException; nested exception is java.sql.SQLException: org.hsqldb.HsqlException: java.io.IOException: java.lang.IndexOutOfBoundsException
	at org.springframework.jdbc.core.JdbcTemplate.queryForList(JdbcTemplate.java:791)
	at org.madsonic.dao.AbstractDao.queryForInt(AbstractDao.java:105)
	at org.madsonic.dao.MediaFileDao.expunge(MediaFileDao.java:729)
	at org.madsonic.controller.MusicFolderSettingsController.expunge(MusicFolderSettingsController.java:92)
	at org.madsonic.controller.MusicFolderSettingsController.formBackingObject(MusicFolderSettingsController.java:74)
	at org.springframework.web.servlet.mvc.AbstractFormController.getErrorsForNewForm(AbstractFormController.java:361)
	at org.springframework.web.servlet.mvc.AbstractFormController.showNewForm(AbstractFormController.java:341)
	at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:281)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:919)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:851)
Caused by: java.sql.SQLException: org.hsqldb.HsqlException: java.io.IOException: java.lang.IndexOutOfBoundsException
	at org.hsqldb.jdbc.JDBCPreparedStatement.executeQuery(Unknown Source)
	... 85 more
Caused by: org.hsqldb.HsqlException: org.hsqldb.HsqlException: java.io.IOException: java.lang.IndexOutOfBoundsException
	at org.hsqldb.persist.DataFileCache.getFromFile(Unknown Source)
	at org.hsqldb.persist.DataFileCache.get(Unknown Source)
	at org.hsqldb.persist.RowStoreAVLDisk.get(Unknown Source)
	at org.hsqldb.index.NodeAVLDisk.findNode(Unknown Source)
	at org.hsqldb.index.NodeAVLDisk.getLeft(Unknown Source)
	at org.hsqldb.index.IndexAVL.next(Unknown Source)
	at org.hsqldb.index.IndexAVL$IndexRowIterator.getNextRow(Unknown Source)
	at org.hsqldb.RangeVariable$RangeIteratorMain.findNext(Unknown Source)
	at org.hsqldb.RangeVariable$RangeIteratorMain.next(Unknown Source)
	at org.hsqldb.QuerySpecification.buildResult(Unknown Source)
	at org.hsqldb.QuerySpecification.getSingleResult(Unknown Source)
	at org.hsqldb.QuerySpecification.getResult(Unknown Source)
	at org.hsqldb.StatementQuery.getResult(Unknown Source)
	... 89 more
Caused by: org.hsqldb.HsqlException: java.io.IOException: java.lang.IndexOutOfBoundsException
	at org.hsqldb.persist.DataFileCache.readObject(Unknown Source)
	... 106 more
Caused by: java.io.IOException: java.lang.IndexOutOfBoundsException
	at org.hsqldb.lib.java.JavaSystem.toIOException(Unknown Source)
	at org.hsqldb.persist.RAFileNIO.read(Unknown Source)
	at org.hsqldb.persist.RAFileHybrid.read(Unknown Source)
	... 107 more
Caused by: java.lang.IndexOutOfBoundsException
	at java.nio.Buffer.checkBounds(Buffer.java:559)
	at java.nio.ByteBuffer.get(ByteBuffer.java:668)
	at java.nio.DirectByteBuffer.get(DirectByteBuffer.java:279)
	... 109 more
gnaaah whats up with this databasestuff ?
EDIT:
btw switching back to the old memorysettings, the error remains
madsonic_sh.log
(205.01 KiB) Downloaded 156 times
madsonic.log
(12.8 KiB) Downloaded 163 times
DoCC
Post by DoCC »
ROFL sometimes AAARGH java is an asshole ^^
after reinstalling madsonic several times,
chaning the networkserver from 2008R2 to 2012R2,
changing from ubuntu 14.04.1 LTS to debian 7.7.0
i got really mad, this damn mediascanner didn't scan my stuff ...
Then i reinstalled madsonic once again ...
copied some essential stuff like users and podcasts from one scripts file to the new one.
This time i added my networksettings via webinterface... guess what ??? now the bastard is working fine ...
i guess, there is something db related crap somewhere preventing to copy the networklocations -.-
so what after an entire day testing around. the bug is located. ...
MadEvil this is another point for putting the admin stuff into an other DB : )
DoCC
Post by DoCC »
Will the graph showing the amount of GB / TB of the files go any further after reaching 1 TB ?
Like 1,1 TB ? Or will it just remain as is ?
