Sometimes you want to change icons, there not consisted in color or you don't like them.
Where is this done ?
Let say you like the theme "cool and clean" but you noticed some inconsistend colors.
In Windows this is the path:
C:\madsonic\jetty\5300\webapp\icons
Most of the times a reload of the page is sufficient.
However image you still find it odd that the Icon above the word Discover is yellow and you want it in black and white as the rest.
You will not find the icon in the path above.
First the icon name isn't discover.png but cover.png one can learn this by right clicking on the icon and save it.
Second this cover.png icon takes it color from the default theme because it's not declared here
C:\madsonic\jetty\5300\webapp\WEB-INF\classes\org\madsonic\theme\coolandclean.properties
I use Gimp select picture ==> color ==> Desaturate ==> average
Put the line below in the the coolandclean.properties file above
coverImage = icons/coolandclean/cover.png
Here you'll find grey icons for Madsonic (Cool & Clean ) theme : https://drive.google.com/folderview?id= ... sp=sharing
Kind regards
Guy Forssman
