Hi guys,
I've recently installed Madsonic 5.1 on my little Raspberry Pi, and i've got a problem !
I tried to watch a video via my android client, D-Sub, and it works well. Then I tried to watch it from the Madsonic web UI, and nothing happens.
When I click on the "play" button, here is what is displayed : (well, i can't post picture... T_T)
Nothing, no player. I tried to use VLC player plugin, and video doesn't load neither.
Do you have some tips ?
Have a nice day ! .
No video player on the web UI
Re: No video player on the web UI
the mobile clients have thier own transcoding engine ...
due to that there has to be an issue with either your trancoding settings, or you have some codecs that are not supported.
as long as you do not tell , which files , which codec and which settings you are using, we can't help any further.
the glassbulb can't effort that much power ^^
