I have tried pulling just the user accounts of the DB and putting it in the new one so that I can move them over...but that seems to break it.
The errors I am seeing is:
Error
Exception org.springframework.jdbc.BadSqlGrammarException
Message PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
Java version Sun Microsystems Inc. 1.6.0_27
Operating system Linux 2.6.32-5-amd64
Server jetty/8.y.z-SNAPSHOT
Memory Used 38 of 191 MB
Stack trace org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:97)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:607)
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
at net.sourceforge.subsonic.dao.PlayerDao.getPlayerById(PlayerDao.java:88)
at net.sourceforge.subsonic.service.PlayerService.getPlayerById(PlayerService.java:177)
at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:96)
at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:66)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:153)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:667)
at java.lang.Thread.run(Thread.java:679)
Caused by: java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
at org.hsqldb.jdbc.jdbcPreparedStatement.setParameter(Unknown Source)
at org.hsqldb.jdbc.jdbcPreparedStatement.setString(Unknown Source)
at org.springframework.jdbc.core.StatementCreatorUtils.setValue(StatementCreatorUtils.java:335)
at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValueInternal(StatementCreatorUtils.java:217)
at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValue(StatementCreatorUtils.java:145)
at org.springframework.jdbc.core.ArgPreparedStatementSetter.setValues(ArgPreparedStatementSetter.java:51)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:591)
... 72 more
Anyone shed some light on this? Is some asshat sql injecting me with bad data into my DB? Is there a file I downloaded with something that isn't escaping correctly?
