Echonest integration
Posted: 22 Jun 2014, 06:21
by HeavensNight
It does a audio fingerprinting, radio,and playlist generation
So for example, if madsonic could generate or look-up Echonest fingerprints for your library, you could select a track, and there could be an option to automatically generate a playlist based upon the musical fingerprint of the "main" track.
Re: Echonest integration
Posted: 22 Jun 2014, 20:36
by gurutech
There's already "Pandora Mode", which does the same thing (although I'm not sure how the similar songs are picked.)
Posted: 24 Jun 2014, 06:29
by HeavensNight
gurutech wrote:There's already "Pandora Mode", which does the same thing (although I'm not sure how the similar songs are picked.)
yeah is almost the same. Echonest is working in fingerprints, read the fingerprints in the song and
recommended the next one, the second song to the third etc, this is spotify radio does. pandora work with the moods and genres maked in the tags,this read the tags of the first song and make a list next ones, but I never could make it work properly.
