What would be the be the easiest way to go about getting madsonic and owncloud on the raspberry pi?
I am looking to retire an old win 98 machine. Its running Ubuntu headless its loud as crap and is probly cugging electricity.
madsonic + owncloud raspberry pi best way?
- Has thanked: 4 times
- Been thanked: 2 times
Re: madsonic + owncloud raspberry pi best way?
installing should be pretty similar to your headless ubuntu install if you start out with a clean Raspbian install, Raspbian is of course built in Debian so make sure you use Debian compatible commands.
i don't know much about owncloud, but if it can be installed on debian you can probably follow those same instructions to install it on your Pi, not sure how well a Pi will perform with both of these running, but give it a try and see what happens!
yeah, but the PI is not the beast man in the field when it comes to IOPs relevant actions ...
i can imagine running a frequently used mycloud besides an proper madsonic may cause some issues with
the processor , the ram or maybe the heat
