i've just noticed that transcoding flac files that include cover jpeg do not work. Other FLAC files seem ok.
Working track :
General
Complete name : The Musical Box.flac
Format : FLAC
Format/Info : Free Lossless Audio Codec
File size : 62.8 MiB
Duration : 10mn 29s
Overall bit rate mode : Variable
Overall bit rate : 837 Kbps
Album : Nursery Cryme
Track name : The Musical Box
Track name/Position : 01
Performer : Genesis
Genre : Rock
Description : FPN
Recorded date : 1971
Audio
Format : FLAC
Duration : 10mn 29s
Bit rate mode : Variable
Bit rate : 837 Kbps
Channel count : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 62.8 MiB (100%)
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
General
Complete name : Breathe.flac
Format : FLAC
File size : 39.5 MiB
Duration : 5mn 35s
Overall bit rate : 988 Kbps
Album replay gain : -8.96 dB
Album : Fat of the Land
Album/Performer : The Prodigy / The Prodigy
Part : 1/1
Track name : Breathe
Track name/Position : 2
Genre : Other
Recorded date : 1997
Cover : Yes
Cover type : Cover (front)
Cover MIME : image/jpeg
PUBLISHER : Maverick
Audio
Format : FLAC
Duration : 5mn 35s
Bit rate : 986 Kbps
Bit depth : 16 bits
Replay gain : -9.51 dB
Replay gain peak : 1.000000
Stream size : 39.4 MiB (100%)
Writing library : libFLAC 1.2.1 (UTC 2007-11-17)
EDIT : solved by add -map 0:0 to transcode command line.
Thanks.
