Madsonic Server 6.3 Synology-DSM 6.1.1
Madsonic 6.3 on Synology
http://www.synology.com
tested with: DSM 6.1.1.15101-4
  • Perl
  • Java Manager 8
Installation:
  • prepare Synology hardware
  • update to latest Synology DSM 6.1.x
  • create new Volume
  • activate user home service
  • install Perl module
  • install JavaManager module
  • download latest Java JDK 8
  • upgrade Java JDK on DSM
  • reboot Synology
  • install Madsonic 6.3 package
  • start Madsonic service
  • logon as admin user
  • set system output to debug
  • check Madsonic log files
Download:
  • DSM Docker
Installation:
  • install Docker module
  • install Madsonic docker image madsonic/ubuntu-madsonic-beta
Download:
  • Java Manager 7
  • Tomcat 7
Installation:
  • install Tomcat7 module
  • download latest Java JDK 7
  • mkdir /var/madsonic
  • reboot Synology
  • install Madsonic tomcat war
  • start Tomcat service
Download:
Oxize
Re: Madsonic Server 6.3 Synology-DSM 6.1.1
Unread post by Oxize »
Not available for normal user. And 6.2 is broken for Synology. So in fact we got nothing now. Not even going to pay if i dont know if it gonna work.
Oxize
Still not working at my side. What you need for debugging/logs?
Oxize
Madevil? What i have to do now? Still getting Failed to install Madsonic. No old stuff are on my nas. Help please.
Fixed installer script is in preparation, coming later this week.
Oxize
Any updates? Newest DSM is 6.1.2-15132
Aktarus
Unread post by Aktarus »
Hello
I have installed the 6.3 vesion on my DSM 6.1 successfully 1 month ago... after long wait time and many install attempt .. and everithing worked fine ...
But I deceide to install the new version 6.3 today... So I uninstall madsonic and it was ok ... backup is in the public folder ..
But when I want to install the latest 6.3 release, I got the FAIL TO INSTALL MADSONIC error... like before...
I tried tio install with and without the backup restore...without any success ...
I tried to install anither old version like 6.2 .. no success ...
So, for now ... no more Madsonic on my Synoloy (DSM 6.1.2) :( :roll:
What can I do ... please help me ...
MERCI BEAUCOUP ... and sorry for my poor english :?
john21wall
Unread post by john21wall »
eevv
Been thanked: 6 times
Unread post by eevv »
Packaged .spk for Synology Madsonic coming in a few days ? With working transcoding and everything? Even for the ds415play with dedicated hw transcoding? Thanks amazing!
These users thanked the author eevv for the post:
Aktarus
