Hello, the transcoding function is not working in my server, If I set the transcoding enabled, the music does not play and the time on the music remains 0:00. How can I debug this, and what can I do to solve it?
Thank You
Madsonic 6.2 Transcoding not working
Re: Madsonic 6.2 Transcoding not working
For example,soloam wrote:How can I debug this, and what can I do to solve it?
show us screenshots of your settings or write them down here.
As well as this useful support-header.
Did you find this post? Its called "WARNING no transcoder found!" and its about the transcode path. Maybe it helps.
