I am having a problem with the "Now Playing" bar not displaying after a few sessions of use. I use this app mostly in my car so a "session" is a commute. I have found that rebooting the phone will allow the bar to return, but barring that, there is no way to access the Now Playing screen until I do so.
I should note that I have seen the same behavior in other Subsonic Android clients I have installed.
I'm not actually certain that this is a bug, as I don't see anyone else complaining, so maybe I just need to be made aware of a setting or control I have missed.
Can't Access Now Playing Screen
Re: Can't Access Now Playing Screen
Now that this post has been approved, a small update: I find that simply backing out of the app until it closes, then re-opening the app, seems to restore the "Now Playing" functionality. Better than rebooting but still annoying.
