Android Client 5.7
in Alpha testing
Release Note
General
- New: add Madsonic 6.0 Support
- New: add Android Lolipop support
- Fix: FollowMe: don't clear playQueue
- Fix: List View don't expand
- Fix: XML settings import
I'm sorry, but the beta test phase only works with the Google Play Store.gurutech wrote:Where can I get a copy of this? I purchased the 5.6 from Amazon store, not the Google Play store...
Will this be pushed to the Google beta group soon or will it probably be some time?Madevil wrote:I'm sorry, but the beta test phase only works with the Google Play Store.gurutech wrote:Where can I get a copy of this? I purchased the 5.6 from Amazon store, not the Google Play store...
At the moment it's a closed group to find the last issues before it goes to the beta group.Soleurs wrote:Will this be pushed to the Google beta group soon or will it probably be some time?Madevil wrote:I'm sorry, but the beta test phase only works with the Google Play Store.gurutech wrote:Where can I get a copy of this? I purchased the 5.6 from Amazon store, not the Google Play store...
