Accessing Madsonic database
Tools & More for Madsonic
Has thanked: 11 times
Been thanked: 105 times
Unread post by gurutech » 24 Jan 2013, 02:55
Just wondering if there's a way to directly access the database through a 3rd party utility, such as Crystal Reports or Business Objects. Can anyone point me towards being able to do this? Looking for something to keep me busy for this weekend, since it's gonna snow, and I may be "trapped" in my house... LOL
Has thanked: 1116 times
Been thanked: 430 times
Contact:
Re: Accessing Madsonic database
Unread post by Madsonic » 24 Jan 2013, 06:48
hi, i used this Tool for SQL Tasks
http://www.razorsql.com/
to access your subsonic db you must shutdown your service before.
Unread post by gurutech » 07 Mar 2013, 05:31
Will def. check this out! Thanks!
Getting error "Cannot find user ADMIN".... Using the Subsonic.Data file - is that the correct one? It's under /var/subsonic/db
Contact:
Unread post by Madsonic » 14 Mar 2013, 22:38
hi,
Database File: /var/subsonic/db/subsonic.script
User: sa
no Password!
this should work!
Unread post by gurutech » 15 Mar 2013, 02:43
I've connected to the db, but I am not seeing any data. I can see table names, but that's about it.
See attachment, I have highlighted "username (pk)" on the left, but nothing shows on the right. Same for anything I highlight.
ForSSux
Has thanked: 10 times
Been thanked: 12 times
Unread post by ForSSux » 11 Apr 2013, 10:37
Hi There
click right in the right upper windowd
Apperently you can also drag en drop the table in the view in Windows
Kind Regards
frank2228
Has thanked: 32 times
Been thanked: 11 times
Unread post by frank2228 » 11 Dec 2017, 02:55
I know this post is old as hell but I am interested in trying to look at/edit the madsonic database.
Are you guys accessing your database locally? I currently have my madsonic installations on headless Ubuntu VMs and administer them remotely from my Windows machine. I am not sure how to get RazorSQL to connect remotely.
Any help is appreciated.
Locked
