Hi There,
I have roughly 20 users wich email all end with @something.be
I thought "clone user" would help me to just copy/clone the user and the change the name and email adress.
The problem is how do I do this ? I could not find any thing about the way clone user function needs to be used.
Kind Regards
Guy Forssman
clone user
- Been thanked: 105 times
Re: clone user
Not sure how it's supposed to work. I just tried it for the first time, and it doesn't seem to work the way I would have expected it to work.
My thoughts are that you would select a user already in your system, and then choose the "clone user" option, which would generate an identical user (as far as permissions and access levels), then allow you to change the name, email address, and password.
But what I'm seeing is that this is basically creating a "new" user, based off the "default" user (which on my system is disabled.)
