Hi!
I don't know if you are familiar with the ViPER4Android app (you can find it on xda), it is an equalizer for Android, which improves the music quality tremendously. I was trying the Madsonic client for Android I found in the forum (Version 4.0.8), to see if it works with viper4android. (I have tried DSub and Subsonic, and both do not work with viper, so I gave Madsonic a shot)
Version 4.0.8 worked fine with viper, so I purchased the current version on the Play Store. But with v5.5.210, viper stopped working. Poweramp for instance plays nice with viper. I can play music with poweramp, and when I start playing with Madsonic, viper stops working after a few seconds, and I have to kill Madsonic for viper to work again (same with DSub and Subsonic). I have tried everything suggested on xda to get it to work, but since other players are working, and the old version of Madsonic was also working, I came to the conclusion that there must have been changes in Madsonic itself.
Is there anything in the audio engine you changed since 4.0.8?
ViPER4Android Audio Effects not working [Solved]
Re: ViPER4Android Audio Effects not working
i don't heard about Viper4Android, but i will take a look.
i have build the source for the Android 4.4 version and debug it on the emulator and found no problems with the new Madsonic 5.6 Client.011992s3 wrote:Thank you very much!
You have to try it, it's amazing what it can do with the sound! I bet you will fall in love too
Maybe a build problem between the old and new version, or a special problem with the ROM or other equalizer apps.
I'll be watching Viper a little during the development.
You are right, Viper have really nice features
OK, I have played around with v4a settings a bit more, and sometimes it would work, and sometimes it wouldnt.
It seems to be working pretty stable now, as far as I can tell.
What I did:
Enable compatible mode and restart. Simple as that.
What I did:
