LDAP authentication not supported by Madsonic 5.7.364
Post your Client Bug Report
troycarpenter
Has thanked: 19 times
Been thanked: 48 times
Unread post by troycarpenter » 04 Sep 2015, 00:13
 VERSION:      MADSONIC 6.0 | BUILD: 7150
 SERVLET:      JETTY 8.y.z-SNAPSHOT
 SERVER:       CPU: AMD
 OS:           Linux MINT (DEBIAN/Ubuntu)
 SYSTEM:       CLIENT
 INSTALLER:    DEB | RPM | DOCKER | OTHER
 JAVA:         1.7.0_79
 BROWSER:      CHROME 44
 CLIENT:       MADSONIC 5.7
 DESCRIPTION:  LDAP not supported
 REPRODUCIBLE: YES
I'm using this against Madsonic 6.0. I've configured LDAP, and the profile I'm using on the Android app is an LDAP user.
When I test the connection in the server configuration screen, it says:
"Connection Failure. LDAP passthrough authentication not supported."
In the madsonic.log file, I see:
DEBUG MadsonicLdapBindAuthenticator - User 'fred' successfully authenticated in LDAP. DN: uid=fred,ou=People
Will the Android app support LDAP? Not helpful if not because all my users are LDAP users.
Has thanked: 1116 times
Been thanked: 430 times
Contact:
Re: LDAP authentication not supported by Madsonic 5.7.364
Unread post by Madsonic » 04 Sep 2015, 00:50
Thanks for reporting,
many builds before i implemented some new LDAP features and authentication changes and must be temp. disabled,
this can now be changed, refactoring come with next builds.
troycarpenter
troycarpenter
Unread post by troycarpenter » 04 Sep 2015, 15:49
Is the change to support this on the client or on the server? I've put in requests for both Jamstash and Dsub to support the new API version, but I would want to give them a heads-up if there is something on the client needed to support this. However, I wouldn't expect the client to need to know the server's backend authentication model.
Contact:
Unread post by Madsonic » 04 Sep 2015, 15:51
next Build 7200 comes with some LDAP enhancements and also the client problem is fixed.
troycarpenter
Unread post by troycarpenter » 06 Sep 2015, 23:23
Using 7200, the client doesn't give the passthrough message anymore. Instead, it can't authenticate the LDAP user at all now. The app says " Connection failure. Wrong username or password". The madsonic log says "Login failed" for user. I can successfully log into the web interface with the same user credentials.
frank2228
drashna
Unread post by drashna » 30 Sep 2015, 15:38
troycarpenter wrote:Using 7200, the client doesn't give the passthrough message anymore. Instead, it can't authenticate the LDAP user at all now. The app says " Connection failure. Wrong username or password". The madsonic log says "Login failed" for user. I can successfully log into the web interface with the same user credentials.
I'm seeing this with ALL users on the mobile app, not jus LDAP. Have you tried making sure it's not just the LDAP authenticated users?
frank2228
Has thanked: 32 times
Been thanked: 11 times
Unread post by frank2228 » 01 Dec 2016, 07:17
Bumping this. Am using 5.7.1 codebase 386. The Connection Failure. Wrong Username or password message appears when either generating an LDAP token or testing the connection. Can also see the bad login attempts in the server log.
On an old stable release 6.0.7860 not using LDAP, I can get the app to test the connection and say OK but as soon as I browse for music it says wrong username or password. The login attempt is noted by the server log.
