Easy playlist owner changes
troycarpenter
Has thanked: 19 times
Been thanked: 48 times
Unread post by troycarpenter » 16 Jul 2015, 15:52
After a recent massive playlist export and import, all the playlists showed up as owned by the admin user. I had to use the Madsonic database editor to change the owner on all the playlists back to the original owner. It would be much nicer (and easier) if the ability to change the playlist owner was built directly into the UI instead of having to build a SQL command for it.
